Results 1 to 4 of 4
Thread: which motor mounts for my 4x4
    Dec 2009
    I've searched and searched again, but I can't find the answer to my question. I've got an 86 chevy silverado 4x4. I plan on swapping in a 5.3 and using the 700r4 transmission that's in the truck. Which motor mounts will work best and mate the engine up with the transmission without having to have new driveshafts made? I've heard dirty dingo makes a good motor mount, but I read that it only works with a 2wd truck. If it makes any difference. My truck has a 6" lift on it.
    I used the dirty dingo mounts for my 92 k1500, also lifted. Quality pieces
    Jun 2010
    I used the car shop inc 1" set back mount adapter plates. I have a 2wd, but my stock transmission did not move any, the 1" back puts the back of the motor where the old on was and bolted right up.
    Mar 2006
    Which mounts did you end up and use? I am about to do the swap in a K5.
