Results 1 to 10 of 16
Thread: Truck Bucks after 6.0 swap
    Apr 2010
    I recently swapped my 5.3 engine out for a 6.0 in my 04 tahoe. We also installed a small gm performance hot cam with a nelson tunned pcm. The truck runs great, but has a less then desirable idle. The problem we have is when you are in drive but at a stop the truck bucks and jerks slighty making you feel like it wants to move when the brakes are on. It is very anoying to deal with. Does anyone have any ideas at what to look for? Thanks guys.
    needs a stall.
    Nothing stock...I either broke it or replaced it before I broke it!!
    put it in neutral
    Dec 2003
    Newark, Tx.
    Quote Originally Posted by 20''strong View Post
    needs a stall.
    what he said
    Apr 2010
    A stall? A diffrent torque converter?
    Broken Bow, OK
    You may need a stall to take full advantage of the cam, but you shouldn't need one just to make it idle without taking off. What is the idle RPM?
    Apr 2010
    It is set to 800 rpm, i orgionally had it set to 650 but it stalled all the time. The truck jerks at stop or going to a stop and actually bucks less at the 800rpm idle then it did at the 650 idle.
    Dec 2003
    Newark, Tx.
    what are the cam specs?
    What do you not like about the idle; lope, speed, etc...
    With a big enough cam, a stock stall will make it act up around idle speeds
    Apr 2006
    Bellevue, Nebraska
    Sounds like when the cam lopes it's trying to engage the converter. Is the converter still stock?
    Apr 2010
    The converter is still stock. The came is a gm performance ls1 hot cam. I actually bought it because it wasn't as aggressive. But it feels like the converter is constantly catching during idle. I did nt think this would happen.
