problems with the 1.8's
ok for starters....i know this isn't a real power gain. anyways, today i pulled my stock 1.7 rockers and replaced them with summit 1.8 rollers. torqued everything down to the spec and got everything put back and tried to fire it up and nothing...... the engine will turn over but there is no hint of it even wanting to fire. i dont know what to do. i checked all the igniton and fuel set up and its all fine. the kit did come with different bolts and washers than the stock set up but the instructions that were sent with the kit said the stock bolts were to be used. so i used the stock bolts with the 1.8's instead of the new bolts. they were the same length so i didnt figure it to be a big deal. when i crank it it seems like the valves arent closed and there is just no compression. i dont understand how such a small change could leave the valves stuck open like that. i could really use any advice if anyone has anything. thanks
'02 GMC Sierra 4.8L
CAI, Granatelli MAF, 90mm TB, 1.8 roller rockers, JET tune, true dual Flowmaster race mufflers.
