Results 1 to 10 of 10
Thread: crinkle bend vs mandrel bend exhaust
    May 2010
    Dallas Texas
    Question crinkle bend vs mandrel bend exhaust
    Ok so I have some new BBK headers to put on my 6.0 but nothing to put on downstream. They have 2 5/8 collectors. I was thinking instead of spending a ton of money on mandrel bent 2 5/8 pipe to fab the exhaust sytem maybe just using like 3 inch crinkle bent pipe instead. The 3 inch should make up about the same as 2 5/8 with all the restrictions the crinkle puts in it, right?? What do you guys think about doing it this way??? I plan on going dual 3 inch into the muffler and dual 3 inch coming out to the tips.
    2000 GMC Sierra Z71 6.0 LQ9, Mahle Forged Flatops, Comp 208/212-554/558 115 LSA, LS6 Valvesprings, Harland Sharp Roller Rockers,Trick Flow 7.4 pushrods, NGK TR55 plugs, MSD wires, Melling High Volume/Pressure oil pump,LS7 lifters, Arp main studs-rod bolts-head bolts, Nelson's 93 Octane Tune, rear 02's and Egr Delete, BBK headers ito true 2 3/4 duals w/dual super 40 flowmasters, built 4L60E, Circle-D 3200 stall
    Houston, TX
    I would say even with the crinkled piping you would still loose to much back pressure. I have 3 inch like stock ot teh muffler then dualed out using the 2 and what ever diameter. Read my signature. I think the crinkled piping kept enoujgh of the back pressure to keep from huting my low end and such. Just my 2 cents though.
    2014 GMC Sierra Crew Cab
    -5.3
    -Gibson Exhaust
    what size primaries are those headers? are they long tubed or short?
    2 5/8s is a rather small collector even for a 6 liter even if it is stock.. i run dynatechs on my ecsb ( all stock ) except tune with 3" dual exhaust i thought it was to much and went to 2.5 duals boy did i screw up
    Simple: 408 on steroids!
    single digits coming soon!
    Go with mandrel bends. It is worth the extra money.
    Plainfield, IL
    I have mandrel bent pipe running from stock Y to about a foot past my cab, it's dumped with no muffler, and i got a LOT of lowend when I did it.
    I don't buy into the 'too much flow' thing, unless you're running open headers on a completely stock engine, you should be fine.
    Dec 2004
    San Antonio, TX Area
    My exhaust is all mandrel bent. I prefer it that way. I just couldn't see myself doing all that work and then having a crinkle bent exhaust.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Jun 2004
    george west texas
    Quote Originally Posted by zeake View Post
    yep and you can get a whole mandral bent exhaust setup for around $250 from www.heartthrobexhaust.com
    get the phone number from the site and get a quote from them...you will be very satisified with it.
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Or buy a builder kit from these guys. Get stainless or aluminized. It works good for turbo tubing, too. http://www.mandrel-bends.com/catalog...400c496c741baf
    Dec 2004
    Forgot about heartthrob, I like them also. I got my bends from summit racing. I used www.heartthrobexhaust.com for one bend that was past 90 degrees. I made a template and took it to a muffler shop, and they crinkle bent it. I then checked the fit on the truck. Once I was happy with it I shipped it to heartthrob and they mandrel bent a piece for me. Perfect fit. Thanks for the link Greg.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    May 2010
    Dallas Texas
    I will take this into advice and prob just go with the mandrel bend set up, the Headers are a set of shorties from BBK I picked up for 150 used, (it was that or reuse the stock manifolds) They look to be almost the same size and dimensions as the factory manifolds but I no longer have them to compare, The only reason I was considering using crinkle bend was I was going to have to run all new exhaust from the headers back (cat delete of course) and didnt want to end up dropping 1000 bucks on my exhaust like my last project My wife will literally kill me LOL Thanks Guys
