Hey guys,
I am in the process of swapping a 5.3 into an 87 Chevy 4x4. I am using the trans dapt motor mount plates with the stock clam shell styl mounts. The first problem I have run into is that if you drop the motor down on the stock mounts it is about 1.75" away from the trans. Not a huge deal, I will weld some plates on and drill some new holes to move the mounts back.
The second issue, potentially more serious is that the front of the motor is hitting the front crossmember. There is no way I will get the power steering bracket and pulley back on. Have any of you guys run into this? I can space the motor mounts up and move them back, I can also box out the front cross member, I just have not seen anyone else run into this so I am wondering if I am doing something wrong.
Any help would be appreciated!!
