Results 1 to 3 of 3
Thread: Tow/Haul button question
    houston
    Its never been answered (atleast from what I've found on the net)... but has anyone wired up a BCM to get the tow/haul workikng?
    The BCM's require programming from the facotry so if you had to program this thing could you through the OBD socket to our conversions? There is a write up on this same question on hptuners, but its for a LS1 computer and its different than our truck computers.
    So if anyones gotten this feature to work, chime in.
    clint
    1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT and HID projectors - also for sale @ $8,500
    A poor man buy's it twice
    Wasilla, AK
    All you need is a momentary switch and wire it up. Mount the switch wherever you want it.
    2001 ECSB 4x4, 5.3, Radix, 3.0 pulley, VHP Trucker cam, 216/224 .551/.551 115 lsa, 1.8 Crane roller rockers, 4L65E, Yank SC3000, 3.73, Cal-Tracs, HPTuners.
    houston
    Could you give connector and pin numbers? From the research I've done it's a momentary ground going to the BCM and the BCM sends a message to the PCM over the Class2 bus
