I was going with the comp LSr 215/223 .604/.610 on 112 LSA w/ 107 ICL.
But the high lift wont get me nothing with stock heads and be rough on valvetrain.
So i'm going with the tsp 220 because of XER lobe. The 112 has 110 ICL and 114 has 112.
Question is would it be worth it to grind 2 degrees advance ICL? (the 112-108; the 114-110). Or split the difference and go 113 LSA with 109 ICL...
I was just trying to be different incase you didn't notice.
Would it be noticeable power band shift downward if i did this? And they all should make within 10 peak hp i would think?
