Results 1 to 10 of 20
Thread: any ideas?
    Cedar Park, TX
    any ideas?
    so my transfer case blew and i got that down to see that its effed. now, i need to know what wrong wit my trans. with the truck running i can shift into every gear just fine, but when it comes time to put it into park, it grinds until i shut the truck off. only in park tho.
    R.I.P Blue '02
    '08 - 5.3
    Vette Servo, Flowmaster 40
    Broken Bow, OK
    That could be because your transfer case was jacked up. If you have the case in neutral with the engine running it will do that when you go from in gear to park. The output is still turning and you are cramming it in park and it is grinding in. If you do this enough times you will trash the parking pawl.
    Are you experiencing this now that the transfer case is off, or before you took it down?
    Oct 2008
    Cedar Park, texas
    His transfer case if off the truck. what your saying makes a lot of sense
    Axekick tuned, Pacesetters, Servo.
    Feb 2010
    Central Texas
    Ya'll you need to link it back up with the rearend if you don't the output shaft will keep turning causing the parking pawl to grind.
    BB
    Oct 2008
    Cedar Park, texas
    It would grind when the case was on the truck, or half way falling off i guess. how could the case be in N? If he was running at 95 in 2wd
    Feb 2010
    Central Texas
    K I'm lost, explain that again?
    Oct 2008
    Cedar Park, texas
    sry, Right now the case is OFF the truck and grinds only in park. He was driving the truck in 2wd, SO how could the T case go into Neutral? Would it not stay in 2wd mode? Idk how that works so maybe im not getting somthing
    Cedar Park, TX
    Quote Originally Posted by vista4.8 View Post
    i was never able to shift my t-case into neutral anyways. i could hold those buttons down for days and it wouldnt go into neutral
    R.I.P Blue '02
    '08 - 5.3
    Cedar Park, TX
    when it happened the truck was in 2hi, after it happened since the tcase is all messed it could've been in neutral. it all makes sense to me.
    R.I.P Blue '02
    '08 - 5.3
    Nov 2009
    chicago, il
    I thought if you're in 2wd, the transfercase is not enguaged. When I look down at my t-case lever, it is in N when I'm cruising in 2wd.
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
