Page 1 of 15 1 2 3 11 ... LastLast
Results 1 to 10 of 145
Thread: LQ4 intake swap for a 4 bolt 90 mm TB
    Lafayette, La.
    Was thinking of using a 90mm (actually 88mm) throttle body off a newer 6.0 & 6.2 truck engine with the 4 bolt pattern but my stock intake is for the 3 bolt throttle body. Does GM make a 4 bolt intake that will work with the regular cathederal port heads on the 5.3L? If I had a 6.0, I'd use the L92 heads and intake swap but don't want to go that route just yet. I've gotten 375+ hp so far out of my 5.3 with a small cam, headers and slight mods but am looking for more. My truck is a 2006 model. Any help in this matter would be appreciated.
    2006 Chevy Silverado Crew Cab Z-71 5.3L, Custom Tune, Volant CAI, 4.10 gears, pacesetter LT's, Y-pipe, high flow cats, comp cam 202/212 500/507 cam, magnaflow muffler, msd coil packs, 1.8 rockers, 31lb injectors
    my 2007 GMT900 is a four bolt TB cathedral port intake. The LS2 intake also works for a four bolt TB and is cathedral port, 90mm also.
    Broken Bow, OK
    search "TBSS intake"
    Lafayette, La.
    Has anyone ever done the swap? Is it worth the trouble? I already have the 90mm 4 bolt TB but have nothing to use it on. Where can I find one cheap?
    There are many on here with LS2 intakes. I had one on my previous engine, Quik has it, TxSilverado I think has it... many if you search.
    casey23 Guest
    so..
    The throttle body is the easy part... or having to install the Intake and TB combo... but you need the Dr X adapter harness to make it work......
    Nov 2006
    Mesquite, TX
    Look here http://www.ls1truck.com/forums/front...take-swap.html
    ...this is what the LS2 swap looks like and is exactly the same as doing the LS6
    geez greg you always leav me out of things
    Thought you had a TBSS intake.
    Nov 2006
    Mesquite, TX
    he does
