I did a search but no luck.. 5.3 Finally came apart the other day. FM turbo Lq4 going in now and i picked up the transmission with it, i also have the harness from a 2005 HD suburban 4x4 and the harness from a 2001 2500 2wd that the LQ4 and 2wd 4L80E came from.
#1 Whats the most efficient way to go about converting the output shaft to to mate to my manual transfer case in my 2005 1500? Do i need to change to the stock 4x4 output shaft AND change the input on my t-case? And how hard is it to do either of these... very mechanically inclined and have built a variety of things... but NEVER messed with a Electronic OD or Newer transfer case before... Local transmission shop quoted me $200 labor to install the output shaft and a shift kit, with me supplying the parts.
#2 Should i just add the required plugs and wires to my harness or use the harness from one of the other vehicles that had a 4L80E? The 05 surburban harness has the transfer case wiring which i don't need... i have a manual case.
Thanks for any and all help! I'm trying to make this as headache free as possible.
