Results 1 to 8 of 8
Thread: flooding issue on the old clunker..
    Oct 2008
    Crimson Tide
    Ok fix after fix i finally got this 78 chevy rollin and ready to play with.. well I installed a holley 600 cfm on it about 2 weeks ago and i didnt do any adjusting beside on the outside air/fuel screws And it ran ok besides bogging at highway speeds trying to speed up...well i dropped it off at the driveshaft guy (done some extensions) and after leaving it there about 5 days ..i picked it up.. and the thing took about 20 seconds to start, had to get out and pull the choke with my hand.. and after starting it idles ok but when any gas is applied it bogs and sputters.. and blowes bluish blake smoke.. i turned the choke back to open too, i also let it idle for about 10 minutes thinking it was flooded but.. still done it.
    And im no carb expert.. im a lift kit guy.. so any help will be Greatly Appreciated!
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
    SLP Cat-back (stainless)
    20in HD hoss black and chrome
    78 Chevy longwheelbase,350,holley 600cfm,6inch lift
    35'' swampers. 87 bed,fuel tank,doors.
    Tyler, TX
    how many miles on the engine?
    www.tjc.edu
    Oct 2008
    Crimson Tide
    92,000 original
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
    Oct 2008
    Crimson Tide
    what i mean by original is nothing has ever been touched on the motor.. also i put a quart of lucas no leak in it and it seemed hard starting after that but it has ran fine just until sitting a few days
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
    Racoon Twp., PA
    Check the float level. (get some clear sites)
    If the floats are too high it will just dump fuel in.
    2013 CC 5.3
    81 C10 LS1 project
    Oct 2008
    Crimson Tide
    ok.. how do i adjust the float level.. i was born into fuel injection world.. carbs look simple but im a dumby on them.
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
    Oct 2008
    Crimson Tide
    just got some good info on how to.
    07 sierra 5.3
    Remington edition
    Afe CAI closed box
    If it idles fine, your float level and fuel pressure should be OK. It sounds like you may have a ruptured power valve. This rubber-diaphram valve is used for fuel enrichment under load conditions. It's located on the back of the metering block, so you'll have to remove the float bowl and metering block to get at it.
