I'm in the process of installing a 4.8 with a 4l60 trans in my 89 chevy truck. The truck had a standard shift. What are the option for a shifter? Will I have to find a column shift or is there a aftermarket shifter avalible?
B&M has some nice truck shifters.
Also, check out Lokar, they have a shifter that looks like a stick shift floor mounted shifter.
You can retrofit an auto shift factory column with all the linkages from a salvage yard, and then there is the flaming river columns...
