I just ordered a comp xr275hr can I run this cam with the stock converter I want to upgrade eventually but it may be a little while before I do. Will this cam run ok with the stock verter and a tune?
Cam
222/224
.566/.568
112lsa
Cam
222/224
.566/.568
112lsa
It will run fine, you just won't be getting the full effect, and it'll lose some low end. The whole point of matching converter to cam is to launch at a higher rpm in the new powerband
Sorry the truck is a 2002 rcsb 5.3l,4l603 trans, 4.10 rear, long tubes, true duals, fipk, 80mm tb
The tune determines drivability.. tc would just optimize your setup.![]()
04 Silverado Z-71 Extended Cab
Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
06 2wd
custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
Also tc keeps truck from surging at red lights if you have to crank idle up a lot.
06 2wd
thats the cam i just bought for my 370
i also purchased a TBSS stall, so yeah, would be a good bet to get a little bit higher than stock stall, even a 2k stall would be good
www.tjc.edu
