Results 1 to 4 of 4
Thread: ls2 front cover on a 5.3 ?
    Evant,tx
    can you put a ls2 front timing cover and cam sensor on a 5.3 if u use a ls2 cam and timing set with a sensor harness ?
    Yes you can places like Caspers make harness adapters and the 2007+ 5.3 is an ls2 with the sensor in the front cover.
    Evant,tx
    awsome thanks for the info. found a decent deal on a cam that uses the front sensor. plus also makes it eaiser when i eventually do a l92 swap.
    Feb 2010
    if im not mistaken it can only be done a gen iV ENGINE..
