Results 1 to 7 of 7
Thread: Cam question
    Augusta, Ks
    Cam question
    I bought a cam from a member recently and am unable to find any information on it. I was told it was a 220/222 .581/.581 114 lsa cam made by crane. However every number I run from the cam brings up nothing.
    Cam says 3720r/3721r hr 114 and has CC engraved into it.
    Havent ben able to find anything on the net but Im assuming it is a Comp cam.
    2004 Buell XB12s
    Oct 2003
    Navarre, FL
    So you don't think that stands for Crane Cams?
    Augusta, Ks
    The numbers dont match the numbers of a crane.
    2004 Buell XB12s
    May 2003
    Idabel, OK
    I always thought CC = Comp Cam.
    I suppose it could be Crane though?
    99 C5 cam/boltons 400rwhp
    10 Sierra CC 6.2
    03 Suburban 5.3
    Those are comp cams lobe profile codes. You can find the specs on their site with a little digging.
    go here http://compcams.com/Base/pdf/lobesection.pdf
    CAMSHAFT TYPE @ .006 @ .050 @ .200 106° 110° 1.5 1.6 1.7
    XE-R for LS1
    Rated Duration @
    .006" Tappet Lift
    LS1 55mm Journal
    3720 269 220 143 0.342 .062 .049 .513 .547 .581
    3721 271 222 144 0.342 .065 .052 .513 .547 .581
    Augusta, Ks
    Thank you sir.
    2004 Buell XB12s
