ok what would it take to make a th350 work in a 2003 rcsb.
yes, but better go 400r
5 out of 6 bolts match up
flexplate spacer
and speedo kit
2013 CC 5.3
81 C10 LS1 project
well i have a th350 with a 9" converter already was just wondering what all it takes to do it. ive seen flexplates for the ls1 so u can mount the th350 and converter to it just wondering what my options are since i already have the tranny
it's not worth that effort to swap it...your best bet is just go with a 80e...take advice from someone who has already done this swap
ok just seeing my options why didnt it work out for u
cruising rpm sucks...kills gas big time, the cost of the swap to a th400 was equal to that of a swap to a 80e and the 80e was easier to do and can be controlled by the pcm still
ive already got the trans. running 3.42 gears and can get just about any driveshaft i need for almost nothing
3.42 gears will put you at about 3200rpm at 70mph. You can get you a DS made to fit it no problem
ya did the math on the gearing with my tires it showed around 2800 prolly just build the 4l60
yeah im not trying to guide you the wrong way but if you have it all apart and have a little time to build it up find you a good 80e core for around $500 and have a rebuild with a shift kit prob for around another $700 and you'll have a trans that'll outlast a 60e/th350.
