Results 1 to 5 of 5
Thread: 6.0 Intake DBW to DBC
    Oct 2008
    Tennessee
    Is a DBC intake on 04/05 6.0 the same as DBW intake?
    Broken Bow, OK
    Are you talking about from a van?
    Oct 2008
    Tennessee
    I found a Intake from truck(04) and it is DBC. I have intake now that is DBW and was wondering if the parts (TB,sensors,brackets) would bolt to the
    DBW intake.
    Broken Bow, OK
    04 trucks didn't have cable, maybe from a 99-02. The intakes are the same aside from some some minor differences.
    Somebody was saying earlier that the 03+ intakes don't have the nut inserts for the cable bracket.
    The throttle bodies bolt on the same.
    Aug 2006
    I used an 05 truck intake...had to cut out some brass nut inserts off an old intake to use, bracket works fine in it.
    86 C10 6.0/4l80e
