Results 1 to 4 of 4
Thread: dbw to dbc
    dbw to dbc
    i bought a 5.3 out of and 03 and it a dbw i want to convert it to a dbc .this will be going in a 89 chevy . what harness mods would i need to make it work . thanx in advance
    San Antonio, TX
    We can build you a new 99-02 harness.
    All you'll have to do is get a throttle body with an iac/tps and it'll work.
    If not, get yourself a 02 truck harness, it'll be setup for a dbc system.
    You can also convert your '03 harness to dbc, simply use the etc wires as the iac/tps and use an 02 pcm.
    i have a spare intake with cable tb and i think i can find the plugs a salvage yard for near nothing .now will the stock pcm work or will i need and 411.
    411. NP can build you a nice harness which will take a lot of the guesswork out.
