Results 1 to 7 of 7
Thread: what sensor is this?
    Dec 2009
    Alabama
    What sensor is this. it bolts to the side of the 4L60E. had to remove the shift linkage to get to it.
    Wichita KS
    gear range selecter.....park neutral safety switch.....reverse light switch
    Did you unplug it first?
    2006 Trailblazer SS RWD
    Dec 2009
    Alabama
    well i am tring to get the one connector you see still connected out. I am sending the harness off to be rebuilt.
    just lift the grey tab, get a small flat head screwdriver and pry, should come out
    Simple: 408 on steroids!
    single digits coming soon!
    Round Rock, TX
    GM was nice enough to put glue in them. Take a hair dryer or heat gun and put some heat on it for about 30secs. It will come apart then.
    Dec 2009
    Alabama
    I finally go tit apart. tore up the connector some but a really small hammer and punch did it. no real harm done. but yes i see now that it was glued in.. *L* oh welll thank yall for the info.
    Gramercy
    when in doubt...beat it with a hammer.
    glad you got it out
    2008 GMC CCSB 6.2/6L80e swap
