Can I run an LS1 or LS2 water pump with truck accessories?
Thanks for your help in advance.
yes, i run the car style ewp .. with my truck accs.
Simple: 408 on steroids!
single digits coming soon!
the ls2 water pump has a narrow bell. Are you sure it can be used with the truck accesories? I know the LS1 pump will work with any accessory group.
If you need alignment help with that pulley I have some 3/4" waterpump spacers to put the Fbody style pumps in alignment to the truck pullies. They're for sale in the classified section, complete with bolts.
Ok, I'll tell the full story. I am building an LS1 and have acquired all the truck accessories. I read on a forum that it is better to use the LS2 water pump as the pulley is shallower and free's up room for the electric fans on an S10 swap. I have a brand new LS1 water pump and 2 used truck pumps. There is an LS2 pump on ebay that is going to end in a couple hours so I was hoping to know so I can buy it.
Thanks so much for your help.
use your ls1 pump since you have it, they both put out the same gpm's if not mistaken
Just a FYI the truck accessories will NOT line up with a LS1 or LS2 pump. You will have to change the pulley to get them to work. Meaning put the truck pulley on the car pump. Only reason to use a car pump is to move the upper coolant hose location. Or use the spacer kit that Red suggested to line up belt with truck accessories
Good info. Thanks guys.
