Results 1 to 10 of 15
Thread: need help with tune up
    south louisiana
    i no i posted something about this before but i cant find the thread. but once again my 05 silverado is in need of a tune up and im asking you guys help with the parts i need. im just wondering whats the best spark plugs,oil filter, and anything else i might need to change. i use to get 20 mpg but i dropped to barely getting 18 over time. she has 93xxx miles on her so i know shes not brand new. i do have a k&n intake and aftermarket exhaust. any help will be appreciated guys
    ff_jeff Guest
    Quote Originally Posted by boudreauxcody@hotmail.com View Post
    NGK tr55 plugs.
    I like mobile or castrol gtx on the oil and filter. Or just a reg fram. Also get a new air filter. K&N drop ins are nice because they are washable, and flow much better than the stocker. It also would not hurt to replace the spark plug wires. Stock replacements are fine, MSD are the best IMO aftermarket.
    NGK tr55 plugs.
    +1
    Wichita KS
    +1 on everything above, and also maybe some lucas injector cleaner. I changed my plugs to the tr-55's and started using 91-octane, and notice about 1.5 almost 2 miles a gallon intown
    2006 Trailblazer SS RWD
    Jul 2009
    Is that the iridium NGK? What about DENSO?
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    ff_jeff Guest
    Quote Originally Posted by Tank View Post
    No not the iridium's... those are $$$ the tr55 are probably the most commonly used by NA ls motors.
    Jul 2009
    Well i need some knew ones cause these E3's are not lasting long and i think they misfire some
    06 2wd
    south louisiana
    Quote Originally Posted by MYSHTBX View Post
    any good sites i can get this stuff from?
    local parts store should have everthing you need
    5.3l-Tsp 220/220 .581/.581 112LSA, Comp 918 revised springs, tsp pushrods-UDP intake, LS1 E-fans, Walbro 255,vette servo, tru cool 40k cooler-4.11s with detroit tru trac. Nitrous Outlet big noid wet system with Harris Speed Works plate and Microedge controller-only on 75 shot........for now!
    Dec 2009
    Houston, TX
    You should also clean your MAF wires with some CRC MAF cleaner spray and your throttle body with some SeaFoam Deep Creep. You'd be surprised how much these two little details will pep things up if you haven't done them in a while (or ever).
    Then run a single can of regular SeaFoam in your next gas tank fill-up (I do this every 5-6 tanks), a third of another can in a top-end cleaning through your brake booster vacuum line (wait 20 minutes and then start your engine), and the remainder of that second can in your oil (and drive for a few miles before your next oil change).
    2006 Z71 Tahoe - Silver Birch Metallic
    GO: Wheatley 93 street tune, TR220-112 cam, PAC 1218 springs, Comp rocker trunions, U/D pulley, LS2 timing chain, JBA headers, cat delete, Magnaflow catback, AEM CAI, 180º stat, ported TB, Circle D 3200, TransGo HD2, billet servos, Tru-Cool 40K, LS6 valley cover, and many more...
    SHOW: Ford keys, 2" spacers, Bilstein 5100, SS cluster, HIDs, LEDs, and many more...
