I am going to have a return rail for the fuel. Whats the cheapest/ easiest way to run the fuel lines?
cheapest.... use some 5/16: fuel line and run a return line to the filer neck to gas tank
easiest..... let a quality shop like DB Rods do a nice fuel system for you... they do awesome work...
You might be able to use what you already have? Add on some high pressure fuel line with a quick fitting to the rail.
@ mic
what kind of fuel pump are you using? similar to stock? run your lines down the basic location that it would on a newer style truck and then use the return fitting on top of the gas tank or, do what Mic said and plumb it into the filler
DamnYankee: my nana failed
What year is your truck with the V6? If 96-up it already has a return line. If not just use the sending unit and pump from a 96-98 and run line to the fitting on the new sender unit.
Yes it is a 97. It does have a return. I meant what fittings/ other things, will I need to connect the v6 fuel lines to the lq4 rail. It also will have a walbro.
I believe russell fittings makes a fitting that will allow you to push it on the stock gm fuel rails and be left with a female or male -6 end.
Since the stock v6 fuel lines probably have 5/16" and 3/8" pipe or straight thread on them, you might just want to cut them off and use some -6an to hardline compression fittings.
Then attach the rail fittings to the new ends on the feed/return lines.
ding ding ding, everyone to their corners
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
Like this?
Retrofit LS1 LS6 Fuel Rail Adapter Fittings Pair AN #6:eBay Motors (item 380171264846 end time Dec-23-09 10:20:28 PST) So get 2 of these, and what do I put on the stock lines once they are cut?
EDIT: or would these be better? Retrofit LS1 LS6 Fuel Rail Adapter Fittings Clamp On:eBay Motors (item 120504317857 end time Jan-08-10 13:40:29 PST)
i just got done plumbing my fuel system on my 82 c10 and i used this russell adapter Russell Performance 640850 - Russell Fuel Rail Fitting Adapters - Overview - SummitRacing.com i ran new fuel lines and AN fittings it was not to bad. i would not reccomend to go cheap on the fuel system. for the hard line you cut you can use this Summit Racing SUM-2200075 - Summit Racing® AN to Tube Adapter Fittings - Overview - SummitRacing.com i had to use one and it seems to work well.
