LQ4 is your cheapest route
Nelson Performance custom wiring harness will be your best friend unless your thinking of doing the wiring yourself.
a sponsor on here does LT headers for the OBS to LSx swap unsure if its just 2wd or includes 4wd
your tranny ive heard of a 4L80E, 6L80E but never a 5L80E what does it come in?
get a 03-07CLASSIC 6.0 an find a 3 bolt DBC TB vs the DBW TB that comes on the 03+ unless your gonna rebuild it anyways then get an 02..its up to you
i used custom machined adapter plates they're heavier duty than the other ones ive seen, 100.00
you'll need fuel line adapter fittings to a -6AN fitting an some SS line
good luck with the build
2008 GMC CCSB 6.2/6L80e swap
