Originally I had 235/75/16's on my 2004 silverado and I've recently put on 2009 Tahoe wheels with 265/70/17's. What should I set the tire pressure at? Stock was 35psi with the 235's
2010 Silverado ECSB LS 4x4. Only mods so far are a K&N drop in filter and a Rough Country 2" front level kit
32/35 area
Cool. Thanks! Thought maybe it would have increased a little since it's a bigger tire.
i usually run 32
35 in everything we run through the shop here that size-ish......
2005 crew cab, new crate lq9 with comp 212/218, 558/563 on 115 cam, 80mm t.b. coated long tubes, off road y, flowmaster cat back, dynomax bullet, ngk plugs, msd wires, k&n cold air kit, 4.10 gears, auburn pro lsd, transgo shift kit, nelson drive tune, trailblazer i-6 torque convertor, anzo lamps, ss front bumper, z71 tahoe rear bumper, debadged, kenwood touchscreen with headrest monitors, JL components, coaxials, sub, 5ch amp. bell tech 2/4 drop. 22x10 ss wheels with 285/35/22 bfgs.
Thanks for the info guys.
what tire pressure should i run with my bfg 285/75R16?
35
now do y'all change pressures if you get thicker tires?
mine now are 6-ply tires, but when i get my next set, i'm planning on getting some 8-ply 285/75-16s. would i continue to run 35psi, or should i bump to 50-ish?
