Results 1 to 8 of 8
Thread: OBDI II port
    SE Georgia
    OBDI II port
    Ok I am finally getting around to cleaning up the wiring and other loose ends and need to get the port hooked up so I can pull codes and tune with HP how many wires need hooking up and can someone help me out with pin #'s or such. I have a schematic of the c100 but have now clue which wires I need out of the computer.
    Tired ol' 5.7, 5.3 swap in progress
    Handle every stressful situation like a dog.
    If you can't eat it or hump it.
    Piss on it and walk away.
    SE Georgia
    Wow nobody has any help to offer?
    What year is your truck?
    SE Georgia
    My truck is an '97 donor 5.3 is a 2002 supposedly. Really surprised I am having this much trouble getting this info I wanted to know how hard it would be to hook up the towhaul option too if someone knows that one...
    SE Georgia
    Here are the pins I found on the ECM that pertain to the check engine and programming.
    58
    DK GRN
    1049
    ECM/PCM/VCM Class 2 Serial Data
    59
    YEL
    710
    Class 2 Serial Data
    14
    ORN/BLK
    1061
    UART Serial Data [Secondary]
    15
    DRK BLU/WHT
    774
    UART Serial Data [Tertiary]
    And here is what I have from the C100
    B6 Check Engine Light
    B7 Serial Data Class 2
    If I had to guess I would say that Pin59-->B7 but I don't know which pin the dummy light should hook to. Am I right wrong some one point me some direction so I can get something done while I am waiting on my transmission...
    May 2010
    so cal.
    # 58 Im pretty sure. Ill be hooking it up tomorrow .
    and the check eng light
    46
    BRN/WHT
    419
    MIL Control
    SOLD:1992 ECSB Silverado lm7 5.3 Swap, TR220 cam, Circle D 3200stall, CBM street tune, Schoenfeld LT's, LS1 efans, transgo hd-2 60e, custom CAI, Autometer gauges
    Best 1/8 E.T. 8.86 @ 77.8 on 275/60/15 MT ET Streets with 1.92 60 ft.
    2000 RCSB 4x4 Lq9 swap...stock except mild 4l65e....for now
