Results 1 to 8 of 8
Thread: Almost Done
    Oct 2009
    Almost Done
    Getting Close 87 shortbed THE BOX ROCKS
    Well guys, getting close to getting this thing running. Here is the low down
    1987 TBI ShortBed, ditched the 4.3 V6 for a L33 Aluminum z71 5.3 Motor with 80k. Used Swaptech motor plates with in 1 inch set back position. Running it behind a Th400 with B&M shift kit factory stall.
    Decided to go with the carburetor setup. Gmpp intake with Edelbrock 1806 660 carb. MSD 6010 Box. Added C5 corvette exhaust manifolds (if you use these the motor has to be in the 1 inch set back position It is also advised that you get the corvette connector pipe although it will have to be modified) This manifolds only leave a 1/4 inch space between the bottom frame sides. Not running cats - 3 inch piping to a set of used C5 stainless Basinis Exhaust exiting out the middle of the rear.
    Added clutch fan for now will install E Fans when I get a Larger radiator ( and I figure how to wire them to a Temperature Relay)
    Added 20 inch matte black GFX wheels with spacers on 55 series tires.
    Will probably lower it 3 front/4 rear.
    Headaches - All that TBI wiring, most will go unused.
    I am using the 2005 alternator still trying to figure which pigtail wires do what and how to hook up properly.
    Nov 2009
    Nebraska
    I was all in until I read carbed It sounds like a cool project but I just can't understand why people don't reap the rewards of fuel injection. I'm not trying to bag on anyone, I think everyone should be able to do things their own way.
    more pics, looks clean
    1996 - BIG BLACK: 5.0 | cognito 10+3 | 22/37 toyo | 14B/4:56 w discs | built 4l60e | corbeau
    1999 - OBS SS RICER: 6.0 lq4 | autometer | jdm! | whipple | FLT billet 4l65 | yank | truetrac
    1954 - OLD RED: Chevy 210 - 3 speed | 235 inline 6
    Plainfield, IL
    carbs have their benefits as well....
    usually make lil more power, a lot easier.
    Driveability and maintenance and gas mileage are really only downfalls.... if its a hot rod, who cares about those?
    Quote Originally Posted by oleshifty View Post
    None of this makes sense to me.
    lol i am thinking about trying out a carb on my setup if i dont reach 500 rwhp
    a carb can get you 30-40 more to the wheels if not more
    op, excellent progress man, seems you dont a great job cant waite to see the final results!!!
    good luck on the finishing !!! touches
    Simple: 408 on steroids!
    single digits coming soon!
    Quote Originally Posted by skeet View Post
    lo
    I find that really hard to believe. Maybe if I were the one tuning the computer vs that carb. I just dont see that. A real tuned computer vs carb? I dont know.
    Plainfield, IL
    not sure exact science behind it, but it's been proven time and time again. I'm assuming it has something to do with atomization of fuel and air before ever making it's way to cylinder.
    injectors are better for gas mileage, and not having to retune for slight weather changes...but a properly dialed in carb will put down more power, assuming the bowls stay full.
