Results 1 to 10 of 19
Thread: maximum bore on a 5.3 block
    Feb 2004
    Western, KY
    I cant find information any where about how far you can bore a 5.3 thinking about putting a 383 in my other truck to can you take them from 3.78" to 4" bore with out the walls being to thin
    Mods:
    Maybe STOCK
    "My lugnuts require more torque than your ricer is ever going to produce"
    Sleep: That Stuff Is Overrated
    "You don't care what it is, or who makes it, as long as they race it. You my friend are a true Gear Head!" (Drew Anderson)
    Who's the real culprit of Obeisity: video games because their scared of physical activities, or Pillsbury for being so delicious?
    ff_jeff Guest
    Quote Originally Posted by ULuze2 View Post
    You can bore it to stock LS1 bore. I believe that is the max. like 3.903 or 3.905. Something like that. I dont believe a 4" would fly on a 5.3
    However that just happens to be stock 6.0 bore though.
    Spring, Texas
    That's correct. You would bore the stock 5.3 from 3.78 to 3.90X or about .120-.125. That's the max you can go without running into cooling issues.
    Oct 2009
    So you can bore a 5.3 to 6.o?
    Plainfield, IL
    a 6.0 is a 4.0 bore if i'm not mistaken
    Pittsburgh, PA
    a 5.3 can become 364 CI but it would be a different beast then your typical 4" bore 364
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Quote Originally Posted by fastlt1 View Post
    No.
    ff_jeff Guest
    No sir, My point was that if you want a 4'' bore, a much much cheaper way is to get a 6.0 block. And go that way.
    Quote Originally Posted by oleshifty View Post
    yes sir.
    Yes, because of a different stroke setup. You would need a 4.1 or so stroke to = a 6.0 lol
    No.
    Yea the maximum bore will be stock ls1 bores from 5.3 to 5.7. Even a 4.8 can be bored out to 5.7 you'd just have to get the crank off a 5.3 or so on.
    6.0LQ4
    4L80-E
    4.56/Detroit Trutrac
    Long Tube Headers
    Cold Air Intake
    OEM E - Fans
    Procharger/Waiting to be installed..
    Jun 2009
    Washington DC
    6.0 or turbo ftw............. or 6.0 AND turbo ftmfw
