84 c10 has 5.3 4l60e swap I'm having a problem where the truck dies as soon I put it in gear
Check your fuel pressure.
fuel pressure is over 50 psi. i got dtc p0740 and p0785
was the trans seperated from the engine during the install? Could you possible have not got the converter in all the way properly? You could have broke the front pump if not true. When you bolt the engine and trans together you should have about 1/8" between the converter and flexplate before the converter bolts go in. The converter should spin freely when not bolted to the flexplate.
the engine and trans were not separated. is it possible the trans is not being powered up so its killing the motor
Not really. No power to trans means 3rd gear starts and no 4th.
Are you sure you have a 60e harness and not an 80e harness?
positive its the right harness i helped take engine, trans and harness out the truck. the truck was a 2004 suburban
Are you positive it has a 60e tune in it and not an 80e tune?
