Results 1 to 9 of 9
Thread: radiator bleeding?
    Aug 2009
    radiator bleeding?
    do i have to bleed the coolant system on my 5.3 in a 78 c10 ???
    Augusta, Ks
    Just make sure to get all the air pockets out of the system through the cap. Is it overheating?
    2004 Buell XB12s
    Aug 2009
    i dont think its getting coolant into the engine i dont wanna run it too long i took out the plug thats on the rear PASS side head to install the temp adapter and no coolant came out also where is the a bleeder on the engine its a 2000 5.3
    Dec 2008
    Sherman, Texas
    its done with the coolant tank cap its a pain
    02 Fully forged Iron Ls1 233/239 595/603 112lsa,
    milled, ported& polished heads,
    K&N CAI, shorty headers,
    off road x-pipe, Pypes M-80s dumped,
    TCI 3600 stall ,TransGo shift kit,
    True Trac w/3:73s, 4/6 drop,
    and a Fast LSXRT 102
    It's easy with an airlift.
    Aug 2009
    ok i havnt fitted the tank yet its a 78 c10 so its not like the factory tank!! someone said i have to sqeeze the top hose hard and fast till the themo opens !! that sounds kinda strange LOL !!!!
    Take the coolant hose off the coolant crossover tube, remove the upper radiator hose from the radiator, pour coolant down the radiator hose until a steady stream of coolant comes out of the coolant crossover tube. Reinstall everything and top off the radiator. It helps a lot if the front of the truck is elevated or on a slope.
    Aug 2009
    thanks RED! ITS WORKED !
    Aug 2009
    hmmmmm the bottom hose doesnt seam to be getting warn the heater hoses do but not the top hose or bottom i might change the themo today its not over heating YET!!
    I FILLED THE SYSTEM THROUGH THE TOP HOSE UNTIL COOLANT CAME OUT OF THE THROTTLE BODY STEAM HOSE ? CORRECT??
