Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 60
Thread: 06 4.8 sts turbo install advice(newbie)
    Oct 2009
    Katy ,Texas
    hey guys after lots of reading and thought i decided to purchase sts turbo setup. im installing it on my 06 silverado crew cab with a 4.8L all stock. it has the intercooler as well. just wondering some tips ,advice, or anything i can do now to prolong problems down the road. especially tranny advice. the truck is on a 6inch lift running 35x12.50s all around. not trying to race it just mainly a little more power.
    Buy an FLT Level 5 or 7.
    What gears do you have? 4.56s would help that tranny lots.
    Oct 2009
    Katy ,Texas
    yea ive looked into the FLTs was gonna go with the level 5 but trying to make this tranny last as long as i can for the time being. at 10psi ill just have to hope. thinking about dropping it to 6psi whats yalls input on this as well seeing that the truck is all stock.
    ryan_prettyman Guest
    Did you already buy the kit because if not I would recommend getting a front mount instead way more efficient don't need to run as much boost and less lag.
    Plainfield, IL
    ditto on gears. normally with boost you want a lower gear...but i know my 5.3 and only a 3.73 hates my 35's. i'd imagine you want around a 4.10. Still semi low for boost, but high enough to where your tranny doesnt hate you.
    lot of guys recommend atleast a shift kit and huge cooler on the 4l60e.
    i'm running same size tires, with 160k hard miles on the clock...waiting for the trans to go in first, then ordering np's new front mount kit. If you didn't order sts already, i'd look into that. More efficient, and 35's throw A LOT of water around when it's raining...can't imagine your turbo will like that.
    Oct 2009
    Katy ,Texas
    yes the kit came with the intercooler setup as well, this kit was purchased from "farmtruc" a while back. heres some pics of the setup
    http://www.ls1truck.com/forums/sale-...-kit-sale.html
    You can always just build a small aluminum shield if your worried about water. You have to completely submerge it to do any harm. Foggy had one on his setup with 33s? or 35s? for the longest time. Meth injection would be a plus, as well as a 40k transmission cooler. I am running two small baby coolers on my lvl5 65e and it will stay around 150-160 after a while of driving
    Oct 2009
    Katy ,Texas
    also this setup i do not have the oil sandiwch adapter. does anybody know what MM i need? this local shop has 65mm and 70mm adapters. or is there any other way to run the oil line without tapping into the oil pan?
    Yeah mine is run with this small plate that is over by the filter.
    Oct 2009
    Katy ,Texas
    yep i did not recieve an adapter! waiting on another local shop turbocagers.com to open hopefully they will carry it ..i hope!
    06 silverado crew cab 4.8L
    STS Kit W/turbonetics BB 60-1 .81AR T4 and intercooler 10psi
    Nelson custom tune
    built 4L60E-hopefully it lasts
    2500 stall-Hughes converters
    42LB injectors
    3.5 Magnaflow exhuast
    6inch lift on 35x12.50s
