Results 1 to 10 of 15
Thread: Newbie - 5.3 Identification
    Oct 2009
    Unhappy Newbie - 5.3 Identification
    Hello people! I am new to the LS game but am very excited to learn. I am in the very early stages of a 51 Chevy truck build up with of course an LS/4L60E
    motivation. I just purchased a 5.3 with 36k miles on it from an '05 Envoy Denali. I do not have the s/n of the vehicle yet but I have several numbers off of the block that I was hoping may help identify it as far as the still mystical codes I am starting to read about.(LS1, LQ4 and so on) Both numbers are on the driver side/rear of the block. Stamped on the block is T52322311. Cast in to the block is 12569513. Any help or direction to look at would be great.
    I'm not sure, But i have a 51 chevy that I will be building in the near future. make sure you document your build because I will def. reference it
    wichita falls, tx
    get a pen light and look in the spark plug hole and see if it has dished pistons or flat tops
    Intro Radicalli's
    Oct 2009
    I've got a bore scope. I will take a look tonight and get back with you.
    wichita falls, tx
    Quote Originally Posted by vintagesteel View Post
    dished = 5.3
    flat tops = 4.8
    Intro Radicalli's
    im pretty sure envoys only came with the 5.3....
    Spring, Texas
    I thought that there would be a 5.3/4.8 stamped on the block as well?? At least that's the way mine is.
    Oct 2009
    Ok...this just in. I can not seem to determine if the pistons flat or dished. If I had to guess I would say flat. I did find 5.3L cast in to the rear of the block and also discovered the block was aluminum. With this information I do believe I have a Gen IV LH6. I cant seem to find the stock horsepower number. I only want this to use as a baseline before adding a few go fast parts. From what I am finding out it appears there is a wide range of interchagability between the LS family engines. Thanks for everyone input. If you can add to my finding feel free.
    yes the envoy came with the l33 aluminum block 5.3 so you have a 5.3 my friend. they dont make an aluminum 4.8.
    CS, MS
    Thats a rare engine to find..
    good job.
    and he is right, they didnt make a aluminum 4.8.
    2000 ECSB Silverado 12.5@111
    1993 RCSB S-10 Stock- for now-
