Results 1 to 6 of 6
Thread: 6.0l engine build up help
    Jul 2009
    Oklahoma City
    ok im about to start building the motor for the truck. i have a 6.0l block out of a 2004 silverado. im trying to build a 10.5 to a 11.5 motor for the track but still have a decent motor for the street. what i need to know is which pistons to use, which rods, which crank (heard factory was good), which heads, which springs and which rockers and which cam. im going to use a 90/90 FAST intake. im runnning the 700r4 with 3:73 gears. thanks for your help.
    Aug 2004
    Magnolia, TX
    which 6.0 did you get? are you talking 10.5-11.5 in the 1/4 or CR?
    Wichita Falls, TX
    Hey man, not to jack the thread but i'm back at Schlumberger. So, I'm takin the same project on as well.
    Get an Eagle 408 stroker kit and be done with it. Eagle rods, crank, Wiseco makes some great nitrous pistons for a decent add-on price to the kit, Hellfire piston rings have taken my abuse for two years. Get the best coated and steel backed bearings you can find. ACL is what I have seen most builders use. The rod bearings are the same as the GEN1 engines so they're not too expensive.
    Jul 2009
    Oklahoma City
    yea in the 1/4 mile.
    southside VA
    +1. That's what I would do if I were u
