Results 1 to 7 of 7
Thread: Wiring Harness question for LS-1 swap into 95 Silverado
    Feb 2009
    Conway
    I've read lot's of post and can't seem to find the answer to the below question. This is my first LS-1 swap and I have a lot to learn.
    I have a 2002 Firebird LS-1 4L60E combo with a computer. I plan to use my factory gages. How much of the factory harness and computer can I remove.
    Any information, diagrams or pics would be greatly appreciated.
    Thanks
    Hutto TX
    All of the factory wiring and computer can be thrown in the garbage....perhaps. Speed/tach should be no problem coming off the new PCM. Oil pressure/fuel/volts/temp come from the senders, but the temp thing gets tricky. I used a 3 wire from a Camaro i think, and its pretty far off. Some people say to do swappy things with oil pressure, but i used the 5.3 one and my gauge works?? You should be able to have all your truck stuff work with either computer. Should you keep your ABS computer? I dunno....
    I'm not 100% familiar with what other 95ers kept and tossed..Jon?
    1991 Silverado ECLB
    LM7-T56
    Oct 2003
    The water temperature gauge works perfect by simply using a 4.3 V-6 sender, placed at the right rear cylinder head, via an adapter(from S & P), because its just an anolog gauge/sender set-up. At least it did for me in my '96.
    Dec 2004
    San Antonio, TX Area
    Quote Originally Posted by r6z4o6 View Post
    I was also told not to use the 98 sensor, because it was way off.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Aug 2004
    Magnolia, TX
    go Coastal Carolina....nothing for the post though
    Oct 2003
    Quote Originally Posted by trsmith View Post
    Thanks
    How is your swap coming along?
    Spiro, Oklahoma
    Quote Originally Posted by Chevy-Art View Post
    I used the three wire sensor and it seems to read about where it should, usually reads right around the first 1/4 mark same as the old 5.7 did.
    1991 Silverado-L33 5.3L, 212/218 .557 .562 115+4, ASP under drive pulley,180* thermostat, 90mm truck intake w/ LS3 throttle body. Shoenfeld conversion headers and duel Flowmaster exhaust. Performabuilt LVL 1 transmission and 23-2500 stall converter.
