If I got a crossmember out of an 80e truck will it bold right into mine? Jwing cuz I have access to one.
no, the frame is different, you'll want to cut the center from your original one and move it back, then brace it with 4" metal plate.
http://www.ls1truck.com/forums/front...rans-swap.html
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
i have a 2001 chevy did a 4.8 swap to a 6.0l with mahle pistons 10.5:1,eagle 6.125' h beams,232 238@50.595 598 lift on a 112lsa,243 heads,44lbs motec IIs,tuned by Nick D,it makes 402rwhp,@5000lbs w/ me in it 13.75@101mph on 22' wheels
Well don't forget that the 2500hd frames are about 1.75" taller than the 1500 frames. I haven't looked under one recently, but I would assume the crossmember mounts are further back as well.
It doesn't seem too hard to modifiy a 60e member so I would just do that unless you just like being different.
you can also buy a modified crossmember from transmissioncenter.net ready to go and you ship them your core back to get a large portion of your money back.
i cant remember if you have the simple crossmember or not.. but this is a easy deal if you have a really 1999 marked as a 2000 like mine..
4L80E 2wd '99 crossmember modification. - PerformanceTrucks.net Forums
2000 ECSB Silverado 12.5@111
1993 RCSB S-10 Stock- for now-
i used the 99 crossmember it was a piece of cake man.
