00 Yukon Denali Big Brake Question
I had this posted up with my new to forums thread. This seems like a better forum for it to be in.....
I have a 2000 Yukon Denali and want to upgrade the front brakes to something bigger and the rear drums to disc. I keep warping the rotors (I'm a little hard on the brakes towing the stunt bikes). Is there a way of using the newer 01 parts? i.e. larger rotors/calipers and rear discs/calipers. Does anyone make the adapter brackets to do so. Welding and fab work is not an issue and I am planning on tearing it down in a week. Just want the easiest route.
Figured the rear disc would have to come in a rear end swap or going with a kit fro Stainless Steel Brakes....
Haven't had an 01' apart to see if I can change out to the larger rotor's with a bracket change and new calipers. I am already running 17" winter rims, so the larger rotor and caliper won't hit the rims.
Thanks for any feedback.
There is hardly anything that is the same between the 00 and the newer body style. Check Baer.
- You may not post replies
- You may not edit your posts
