Hi guys! 1994 GMC 1500 swapping in a 2002 5.3/4L60E
Hi guys, I am Jon from Cocoa, FL.
I am starting my first (personal) LSx swap, I went over to Tampa and picked up a 5.3/4L60E, all the wiring/ECU, fan shroud, radiator, A/C system, exhaust, EVERYTHING out of the front of the truck. The combo will be going into my 1994 GMC 1500 ext cab to use as a tow vehicle for my 1984 z28 with my carb'd 360ci SBC with a 150 shot on it. With a smaller cam, no stall and a 100 shot the engine went 12.0 @ 112 in my 95 s10.
Here is a quick rundown of the swaps I have done:
1986 s10 ext cab with a 360ci/700r4 (mine)
1995 s10 reg cab with a 360ci/TCI TH350 and a 100 shot (mine)
1994 Z28 Camaro LT1 swap (dads)
1978 Datsun 280Z with a 355ci/JW TH350 (friends)
1998 GMC Jimmy with a LQ4/4L60E (dads)
2005 GTO now equipped with an LS3 we swapped in. 475hp at the wheels (dads)
1984 z28 camaro with the 360ci/TH350 150 shot (mine)
I will be here for a while trying to figure the wiring out on the GMC/5.3 swap. Thanks guys!
- You may not post replies
- You may not edit your posts
