Sorry to be such a noob but can someone explain what an SD tune is exactly? Also when and why is it necessary to go with SD tune? Thanks for all the great help guys
SD stands for speed density and is normally done on forced induction or large cam applications. It deletes the MAF sensor and uses a 2 bar (or 3 bar if running over 15 psi) MAP sensor. This allows fuel to be added based on boost and atmoshperic pressure rather than just air flow across the MAF. In higher boost situations, the MAF sensor becomes maxed out and can't measure the amount of air coming across. A good tuner can still tune with this but it becomes more of a guess. Overall, SD is more accurate.
great info thanks man so I can wait at least untill the cam swap to go SD
I have a speed density tune.
