Results 1 to 5 of 5
Thread: Drivetrain Donor Selection
    Feb 2006
    I have a 1998 Tahoe 2 Door 4WD with the NP246 Autotrac transfer case and I am trying to figure out which donor vehicle I should be looking for so I can use at least my stock front driveshaft and hopefully the rear as well. From what I've read so far it looks like a 1999-2002 1500 Silverado / Sierra or Tahoe / Yukon that has the NP8 option(np246) will have the same output shafts as the tcase that's currently in my truck. Can anyone confirm or deny this? I am also curious about the wiring for the dash switch as well.
    I've been wanting to swap my 5.7 to a 5.3 or 6.0 for some time now and now that my tcase is going out(which is $1000 alone) I figured I can justify spending the $2500-$3000 it would cost for a complete salvaged donor truck from a local salvage auction. Then I'll be getting engine, trans, and transfer case, plus any odds and ends that I may need off the donor.
    Any input would be appreciated.
    Fort Worth, Texas
    My 2001 Silverado has the 5.3/4L60E/Auto Track Transfer Case (I believe NP246), I'm pretty sure your info is correct.
    2002 Silverado 2500HD LB7 CCSB LT
    EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
    2004 Tahoe LT
    2006 Silverado Z71 LS
    1971 Chevy C10
    NP8 = 246 right?
    Feb 2006
    From what I've read that is true. I have heard, though, that different years of the NP246 have different output shafts and possibly different encoder motors and therefore different wiring.
    Feb 2009
    mississippi
    you could prob use the yokes off the doner but still use your drive shafts
    04 1500 5.3L custom hp tuners tune by myself don have a pic of it yet so hear is my old 01 chevy 5.3 460hp 13.669 @ 116
