Results 1 to 3 of 3
Thread: engine swap cooling
    engine swap cooling
    My 88 suburban Radiator is in good shape and is 32x20 so it is pretty large. Will it be ample cooling for my 6.0lq4 that i will be using? I also have an oil cooler factory that i will be using if that helps.
    Dec 2008
    Del Rio, TX
    I went on ebay and bought my radiator for about 270. Its all aluminun and a 3 core. Yours is a little larger than what I have, I say use it and see what happens. Sounds like it should work.
    1993 Gmc 02 ls1 Circle D 3400 stall, long tubes, 220/224 cam stage 3 heads, weiand intake, auburn posi, 389rwhp 352ft/lbs
    May 2007
    i used a griffin dual 1 inch core ...... from summitracing was 169.95
    if im not mistaken summitracing has the same radiators that are summit brand and are cheaper right now .....
    143.95 on sale right now
    Summit SUM-380331 - SummitŪ Aluminum Racing Radiators
    im using the griffin version of the same setup 31x19 dual 1 in core
