Results 1 to 4 of 4
Thread: 5.3 into a 95 Sierra HELP!!
    Hello to all,
    I am doing an install of a 5.3 Vortec motor into a 95 Sierra with a 5.7. I completed all the of the mechanicl install and I seem to be hung up on a few pieces of wiring.
    What I am looking to know is what wires will control the LED's behind the PRND321 indicators??? I have found Park, Reverse, and 2nd as they were located by the stock ECM under the passanger side dash but I cannot find the others.
    Has anyone confronted this part of the install??? I have gotten all of my gauges to work properly, and this is all that is left so that I can start tuning.
    Speaking of tuning.... I will make another thread for an idle issue I am having.
    Thanks in advance for all of your help and I look forward to contibuting help here!
    Oct 2003
    Chris, you've got to get the wiring diagrams for both your truck, and the donor motor. Things changed every year, in the mid-90's. Transition years with GM, with regards to wiring.
    Quote Originally Posted by LS1GMCTruck View Post
    Thanks for the response!
    I have the Haynes Manuals for both and the problem is on the truck side of things, (By the way I am using stock tranny with his stock drive indicator switch/neutral safety switch attached to it)
    Nowhere in the manual does it cover this wiring scematic. Would I need to see a service manual??? If so where should I look for one if I need it now??
    Also, if anyone has the answer to the original question then please post!
    Thank you again
    Oct 2003
    GM Service Manuals for your year truck available on E-Bay. Haynes are poo-poo.
