Results 1 to 9 of 9
Thread: What harness?
    What harness?
    Well i hope you guys dont mind me being on here but i need some help. when i say "mind" i mean im putting a 5.3 into a astro van and not a pickup. im just wondering with the few companies out there where should i buy my harness?
    i just picked up a engine and trans out of a 2008 Tahoe, 5.3 w/ 4l60e.
    thanks for any info
    Ken
    Dec 2004
    San Antonio, TX Area
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    08 is a different animal than most here but can be done.
    Feb 2009
    mississippi
    i thalt the new trucks hat the 6l90e
    04 1500 5.3L custom hp tuners tune by myself don have a pic of it yet so hear is my old 01 chevy 5.3 460hp 13.669 @ 116
    This is the one i went and picked up eBay Motors: 2008 Chevy Tahoe 5.3L 2WD Engine Trans Street Rod LMG (item 370158861396 end time Feb-26-09 10:42:43 PST)
    it could be a 07' then? Will i still have to get the TAC module?
    if you look at this harness from Current it looks like they bypass the TAC module LS2/LS7 harnesses by Current Performance Wiring
    I just want this install to be ass easy as i can get it. Also off the subject, i can put a ls6 intake on with no prob also right? I just want it for clearance issues. The van is body dropped so i had to Z the front sub frame 5 1/2 inches so now the engine is that much higher.
    Thanks again for any help
    Ken
    Feb 2009
    mississippi
    yea about the ls6 intake you will just need rail and injectors and the water pump there is a sticky on it and if its a 4l60 you can but if its a 6l90 your gona need the ecm and tac
    So i called nelson and they only have harnesses that are cable throttle bodies and not DBW. does anyone out there make a harness that is DBW?
    speartech and many others. There is a list of wire harness manufacturers on here somewhere. The search button is your friend.
    talked to Speartech and im shipping them my harness for them to make it work for me.
    thanks for the help
    Ken
