Results 1 to 10 of 23
Thread: Tap and bit ?
    Nov 2006
    Mesquite, TX
    Tap and bit ?
    going to use a -10an for my drain on the turbo, i need help on what size bit and tap to use and where to get it at. I already have the -10an fitting and it's big i think it's a 1/2....if anyone could point me in the right direction or if someone has the bit and tap i could borrow i would only need it for a couple of hours, i know these things arent cheap at all.
    Thanks
    Pittsburgh, PA
    i got my fitting at HD and i went everywhere a local hardware store had the tap i needed. i paid i think 20 bucks just for the tap. -10 is 5/8 when i head to garage today i can get specs for you of the tap i bought and used.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Nov 2006
    Mesquite, TX
    dang bigger then i thought, if you wouldnt mind i would greatly appreciate that
    Pittsburgh, PA
    Quote Originally Posted by mean05 View Post
    yupp if someone doesnt chime in before i should have it for ya later today.
    also for the whole - scale take it from 16 and that is your size roughly
    -4 =1/4
    -8 = 1/2
    -12 = 3/4
    and so on
    412 Motorsports
    Yep, put the dash number over 16 and reduce the fraction.
    Nov 2006
    Mesquite, TX
    good thing i like math 10/16 = 5/8
    Pittsburgh, PA
    see im not just all good looks you know now wheres my ASE certification
    412 Motorsports
    Pittsburgh, PA
    O btw for the drill bit i used a Step-bit. this seemed to work best and cheapest.
    also since its aluminum the step helped to not crack the pan from a normal bit biting
    412 Motorsports
    Nov 2006
    Mesquite, TX
    i have a unibit here at work i can snag....just let me know the tap i need if ya dont mind so i can get that knocked out also
