Results 1 to 4 of 4
Thread: Wich adapter plates?
    Hi i have been searching for a for sure answer so i can order the right ones the first time around. I have a 1994 rcsb with a 4.3 and am puting in a 04 5.3 and 4l60e. Should i get the one that puts the motor back one inch or not. I want the one that will allow my stock driveshaft to work. Thanks so much Justin.
    Oct 2008
    Temple, Georgia
    Use the Hooker plates that Jeg's sells. I am using them on my 89 Silverado and they are working wonderfully. They are not the regular plates, they are the ones that move the engine one inch(Approximately). This is the link, Hooker 12611 - Hooker Headers LS1 Engine Swap Headers - JEGS
    Ok thanks man i was not sure if i should go with the one inch back or the other way. I just did not want to make more work for my self if i didnt need to. oh and about how long would you plan on the swap taking if you have all the parts ready to go.
    SA, Texas
    Hey Justin
    Your Harness will be arriving on Monday!
    Thanks
    mel-
    Her name is A Meli-
    "If everything is under control, you are going too slow."- MA
