My buddy and I swapped a 4L80E into a 99 Silverado(NBS). We got the pins in the right slots(22 and 23) and bought Nelson's adapter kit. But the truck won't run correctly. Before the speed sensor wires were hooked to the ECM, it ran like it should, it just wouldn't shift correctly. After connected pin 22/23, it won't take WOT. It kinda just makes a lot of noise or just bogs down like the pedal isn't being pressed. We are sure the truck had plenty of gas, fluids were fresh and topped off. No vacuum leaks.
Here's what it does. He takes off from a stop - full throttle, won't break the tires loose(No TM) and barely moves the truck. Max speed with pedal floored was around 60 or so and took a long time to get there. The trucks would sound very rough and out of tune. But when he uses part throttle, the truck hauls ass like it should and the trans will shift like it should and the truck sounds smoother aswell. Another thing we noticed is that it's moving in neutral and reverse doesn't seem to work...as if it's locked or fighting a forward gear....the truck will rock backwards then jump forward.
I realize the Neutral and reverse problems could be linkage related, but that doesn't explain why WOT doesn't work. I'd appreciate any ideas or advice.
