Results 1 to 10 of 20
Thread: Driveline Vibration Part 2
    Needville,TX
    Ok I going to solve this problem once and for all...I hope.
    The only thing original on the truck since the old setup is the rearend and drop kit but playing with the pinion angle seems to change the vibration intensity.
    Right now its set at maybe -1* on the trans/eng and the rearend is -3to4* pinion angle.
    The vib is really noticable now at this setting at the speed of 65-70mph and the faster you go I guess the harmonics of it change and it smooths out.
    Look at the crappy way DJM adj. pinion angle...
    89' GMC RCSB 6.0L LQ4, T56, 4.56 Gears
    S.A. Texas
    I am having the same problem, i am just trying different shims looks like i need the 2* shims
    Needville,TX
    Quote Originally Posted by murdered_outgmc View Post
    Well at least I can say Im not the only one with this problem. Only thing is mine doesnt use shims.
    Whats ur lowering setup?
    Racoon Twp., PA
    I would take off that clamp style flip quick and weld some perches on there. That thing is gonna spin and break stuff.
    2013 CC 5.3
    81 C10 LS1 project
    Winnipeg, Manitoba, Canada
    Quote Originally Posted by tanz45 View Post
    X2, thats a pretty 'ugly' flip kit... Make sure you know your angles for sure (dont guess).
    Jun 2007
    maine
    hey man any progress lately??? i finally had time this morning to throw mine up on 4 cylinder blocks on the garage floor and measure out my pinion angle. currently my Transmission is sitting at -2 degrees and my rear end is at a positive 5 degrees. i want the driveline angle to be at -2 degrees so im 5 degrees out of wack on the rear end and already have a 4 degree shim in there. im hoping this is whats causing my vibrations which is only muliplied by that fact that i have 4:56 gears and the shaft is turning pretty fast. do you have any idea if CalTracs allow you to adjust pinion angle? or how the heck your supposed to compensate for being so many degrees off. thanks bud hope all is well with the truck!
    Round Rock, TX
    The Ideal setup is to cancel out all the angles to 0 total and keep the ujoints within 4*.... So if the trans is pointing down 4*, you want your rearend pointing up 4*, this creates the same angle front to back, and keeps the ujoints in phase with each other. This is also on a stock height vehicle.
    Now comes the problem, everyones truck is lowered and these angles become more severe, and the above statement doesn't always hold true. You can usually start out by shiming the tranny mount up to reduce the angle up front. I like to get it to around 2-3*pointing down, now you need to shim/correct your rearend angle to around 1-2* degrees pointig down to help with wheelhop and correct angles under load. The rearend will roll up a few degrees with leafspring flex under load. These angles are within range to keep nasty vibrations away during acceleration and during cruising speeds. And usually once you get all of this set go ahead and change the unjoints again due to any failure that might have happened before to bad alignment....
    Jun 2007
    maine
    Quote Originally Posted by DBRODS View Post
    makes perfect sense to me. i can probably shim the trans to 0 degrees but as far as getting the rear end to a -2 degrees i would need another 5 degree shim on top of the 4 degree one i have thats 9 degress that doesnt even seem right to me that a drop kit put stuff so far out of whack like that... any suggestions on getting the rear end to a -2 degrees? i know your pretty good with rear suspensions. and i mentioned cal tracs because i heard you can use them to adjust and hold a solid pinion angle and i need a set any how. im just trying to determine other options that having huge shims under my rearend. thanks! hell i wish i had the setup you guys did on rickys truck thats badass. to bad you dont market the setup id buy it in a heart beat cuz my truck squats and almost touches the roll pan off the ground when i really hammer it.
    Needville,TX
    Quote Originally Posted by Wtfan18 View Post
    Man I cant see how ur 5 degree pointed up, it needs to be pointed a few degrees down.
    My trans is at 0 degree and my rearend is at 3.5 degree down. The vibration is still there and it not bad at all. Just at 70mph and after that its gone.
    I installed a belltech flip kit that uses shims which made the adj. alot better.
    Wheelhop is still there and I dont get it why, I never had a problem with it
    Get some pics of that reareand.
    Needville,TX
    I have a ? for you what shocks are u using with ur drop? It's probaly 4 link'd right and are u using traction bars
    Are you meaning the trans angle on the pan or the yoke?
    I get what ur saying but for some reason its not helping me out.
    I cant lower my trans angle only raise it due to me using the factory crossmember.
    Thanks
