Results 1 to 3 of 3
Thread: Brand New Fuel Injectors, Various Sizes
    Apr 2004
    Indianapolis IN
    We have the following injectors available if you are considering an UPSIZE:
    42 lb 8 Items $316.00
    50 lb 8 Items $562.00
    75 lb 8 Items $562.00
    84 lb 8 Items $623.00
    95 lb 8 Items $670.00
    Other sizes maybe available if needed. These prices are for a complete set of 8 !
    Each New Injector is balanced and shipped with similar flow rated injectors.
    <div align="center">------ Todd -------
    http://www.turbols6.com/albums/LS6-Typhoon/aby.jpg
    The only thing left STOCK on my truck is the shadow*
    * this is subject to change if I can find a kick ass mod for it</div>
    Dec 2003
    42 lb 8 Items &#036;316.00
    50 lb 8 Items &#036;562.00
    75 lb 8 Items &#036;562.00
    84 lb 8 Items &#036;623.00
    95 lb 8 Items &#036;670.00
    Other sizes maybe available if needed. These prices are for a complete set of 8 &#33;
    Are these for the new body style trucks or do they require some kind of modification like the ls1 injectors? Great prices.
    http://images.cardomain.com/member_i...58_26_full.jpg
    1999 Silverado Stepside
    Performance Mods- LQ4 6.0L,TR224 cam,worked heads,Comp918s,Thorley Headers,Nelson Tune,Magnaflow mufflers,Magnaflow xpipe,electric cutouts,TCFuddle 3800 stall,TeamTripp tranny,3.73gears,airaid mit,poweraid tb spacer,LT1 fans,permacool cooler,Nelson harness NX happy gas
    Fast enough to crack your mustang&#33;&#33;&#33;
    Best 1/8th et- 7.40@93mph with a 1.92 60ft(spinning)
    Best 1/4 et- Find out yourself&#33;
    Apr 2004
    Indianapolis IN
    I just contacted FAST to verify, the injectors are indeed the same as the standard universal injector.
    The critical areas are the Oring and PINTLE area, these are all identical. The actual housing maybe slightly different from Injector to Injector (due to manufacturer variances) but the injectors themselves are the same.
    There are HIGH and LOW Impediance injectors availabe, perhaps thats what you were questioning. The Cut-off is at the 50# rating. The 50# and lower are HIGH IMPEDIANCE Injectors. The injectors greater than that rating are LOW IMPEDIANCE Injectors. However they ALL remain the same physical size.
