Results 1 to 10 of 10
Thread: Clutch is here! woo hoo
    Florida
    although still got parts to collect
    the man in the big brown truck dropped it off today
    Stage 3 Carbon...fucker will hold 700ft-lbs. of tq
    SPEC Billet Steel Flywheel
    still need:
    master cylinder
    pedal assembly
    harness(?) maybe...might still go painless...yes, i fear the harness...again
    and last but not least *cough* CUSTOM MOTOR MOUNTS *cough* allen *cough*
    and i wanna replace all the carpet from grey to black while i got seats out.
    also, allen hows the ac bracket comin along? think it'll be ready in a few weeks?
    Brandon
    Hugger Orange 99 SS Hardtop #756
    485rwhp/440rwtq SAE
    http://i83.photobucket.com/albums/j301/slmdls1/Signatures/hugger-prostar-sig.jpg
    San Antonio, TX
    man that's too bad, you should have went with a stronger one, jk,
    cool, now get that badboy in there and see what it feels like.
    later,
    allen
    Sterling, VA
    There goes your rear end.
    1991 Formula Firebird
    2001 LS1/4L60E, 3.23 posi rear
    Comp XE 216/216 .577/.577 114LSA cam
    918 Springs, hardened pushrods
    Yank SS3600 torque converter
    PCM reprogrammed for cam and converter
    3" exhaust
    BRM Adjustable torque arm, tubular read LCAs
    Spohn Adjustable panhard bar, front steering brace
    Spohn Subframe Connectors
    4th Gen style wheels
    Bilsteins sport struts and shocks
    San Antonio, TX
    haha, you're right sorg, that's how it works, i've already done my trans, now i'm working on the driveshaft, after that, i'm sure the rearend is going to take a sht,
    oh well, that's what happens when you wanna play,
    allen
    Florida
    later,
    allen
    stronger..... cant imagine the chatter and sharp engaging the stronger ones have...i've felt br1ev8's Stage 3 on his LT1 and thats what i call borderline....hopin its a bit smoother with the LS1
    dont think the rear will hold? 3.42's open diff baby!!!
    i gotta set of 3.73's thaty i was gonna sell but may use em....all i need is $$$$ for a posi
    Brandon
    485rwhp/440rwtq SAE
    San Antonio, TX
    ya, you're right, until you put that traction to the ground you'll be fine, it's just a chain of events though, you get something stronger and the weaker parts start to break,
    good choice on the clutch,
    allen
    May 2003
    who'd you get your clutch/flywheel from?
    San Marcos Texas
    I figured it would be made of aluminum like the driveshaft!!
    San Antonio, TX
    hahaha, lmao, funny jeff
    Florida
    SPEC (Star Performance Engineered Clutches - thats just a guess)
    aluminum flywheel was another $179 with a lightweight clutch pack optoin for another $79. i went with steel cuase its a 4000lb truck at least...needs a little beef in there for strength
    Brandon
    485rwhp/440rwtq SAE
