Results 1 to 10 of 34
Thread: 95 chevy finally getting the LS2
    Round Rock, TX
    The truck is finally getting a LSx conversion. I started last night with pulling the old motor out. The TBI just wasn't cutting it anymore. I've been playing with a few different adapter plates to position the motor a little further back in the engine compartment. I actually think it is in a decent position now. Here are a few pics to get started.
    ff_jeff Guest
    Looks good Jon. You should have called me.
    Round Rock, TX
    Don't worry jeff it will still be in and out probably about 10 more times.LOL
    May 2006
    Waco TX
    Sweet! I can't wait to see what times she puts down!
    Ill have to delay your finish time with $$$ but then you will buy more go fast parts. I am going to lose either way lol. Looking good.
    Are you using that yellow pan as a toilet to get it done faster?
    badass jon! if you need any help give me a shout
    Hurley, Mississippi
    Cool. I've got a '95 ecsb that will end up with an LS motor after i finish the '85. Looks good so far.
    '86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
    Dec 2008
    Del Rio, TX
    Lookn good! I hope to see that thing when its running. Wish id had put an ls2
    1993 Gmc 02 ls1 Circle D 3400 stall, long tubes, 220/224 cam stage 3 heads, weiand intake, auburn posi, 389rwhp 352ft/lbs
    Looks good in there. Did you do a crank spacer, longer bolts and flat flexplate so you can continue to use your stock transmission or are you going to swap to a 300mm style LSx transmission from something late model?
    Quote Originally Posted by DBRODS View Post
    The true sign of a fat kid that doesn't want to expel the extra energy to use a cherry picker... Heaven forbid you have to crank the lever a few times.
    FAT A55!!!!
    P.S. You made a bigger mess of the floor than I did with my motor swap... both of them put together.
