I have an 03 silvy with a 4.8L with 146k miles on it. Well, the check engine light came on awhile back with the code P0332, knock sensor low circuit input (bank 2). Well, i sent the truck to the shop and had the knock sensor replaced. well on my way home from the shop the check engine light came on again. code P0332, same code as earlier, so i sent it back to the guy and he replaced the knock sensor and wiring harness to the sensor. well 2 weeks later the light comes back on and its the same code p0332. well, now the guy is insisting that the motor is knocking, but i would figure it would throw a different code then the P0332 if the motor was knocking. Just need some help trying to figure out if i should send it back to him and have another sensor installed or are there any other people who have had this issue and have resolved it.
