Results 1 to 10 of 15
Thread: It Lives!!
    Hutto TX
    It Lives!!
    91 Silverado. Stock 5.3 from 2001 Burban. All 91 wiring is removed from truck other than fuel pump and rear stoplamps. 2001 Suburban junction block and all underhood electronics present. Relocated battery(and washer bottle) to front driver's side.(PCM underhood but yet to find a home.)bout 6 wires through firewall to 95 fusepanel and 9x steering column in order for it to run. Fuel pressure 55psi KOEO. Open exhaust manifolds, no 02's installed yet.
    I could wet my pants i'm so excited!!
    Have to button up exhaust, get coolant temp into the cab, and borrow a scanner to make sure all is well before i test drive it. Resurface brakes and repack bearings been off the road for about 2 years now. Thanks to Nelson Performance, LS1truck.com, A-Line in round rock, Rick's Napa in Hutto, Mike over in parts at Hewlett Chevy, wtfan18, long&low, T.Spell, Fidel in B/CS TX(fuel pumps works great) and anyone else who has lent a hand or otherwise. Gimme another month or so and i should be banging through 6 gears!
    1991 Silverado ECLB
    LM7-T56
    Dec 2008
    Del Rio, TX
    Pretty sweet man! Hope to see that thing at the SAR event!
    1993 Gmc 02 ls1 Circle D 3400 stall, long tubes, 220/224 cam stage 3 heads, weiand intake, auburn posi, 389rwhp 352ft/lbs
    wichita falls, tx
    wow...complete harness....props man...hope it turns out good in the end!!
    Intro Radicalli's
    Nice. I love it when a plan comes together.
    Apr 2005
    AWESOME!
    Ricky & Mike are great guys! I have known Ricky for 25 years!
    Gone, but not forgotten!
    Jun 2007
    maine
    awesome man! wait till you drive it! you wont stop smiling for days, the 6 speed makes it all worth while, not sure what you have for gears but youll prolly need a new set and a locker if they are stockers ahha. my first gear went till about 55mph! and id roast 1 tire 1st, 2nd, most of 3rd, and chirp 4th. LOL they were only a 215/75/15 tire but damn it was fun. CONGRATS!!
    Sweet!
    man thats nice!!! glad its going your way!!
    Simple: 408 on steroids!
    single digits coming soon!
    Spiro, Oklahoma
    Congrats on the start up. I noticed your fuel guage goes way past full, does it do that all the time? I ask because since my swap mine has done the same thing and I can't figure out whats causing it.
    1991 Silverado-L33 5.3L, 212/218 .557 .562 115+4, ASP under drive pulley,180* thermostat, 90mm truck intake w/ LS3 throttle body. Shoenfeld conversion headers and duel Flowmaster exhaust. Performabuilt LVL 1 transmission and 23-2500 stall converter.
    Jun 2007
    maine
    Quote Originally Posted by low91 View Post
    yep mines the same way. theres a post on this site of how to fix it somewhere.
